No reviews yet
There are no independent reviews of Primo V3 yet.
Read the reviews of Primo V2, the previous modelStreamer DAC
The redesigned Primo, with ESS ES9039Q2M conversion and adjustable XLR and RCA outputs.
Reviews
Primo V3 is designed and made in Florence.
Made in Florence
Primo V3 is designed in Florence and assembled there by hand, by the team that also writes its software. Each unit is checked before it leaves the lab.
More about Volumio in FlorenceLook inside
Primo V3 is a complete redesign of the original Primo. A linear power supply stage and a high-precision clock keep noise and jitter low, and the layout keeps every current path short. Along the edge sits a hidden nod to Florence. Pick a part to find it on the board.
Sound
Pick one of eight DAC filters, with Minimum Phase as the default. Or switch on NOS mode for conversion without oversampling.
Set the level to suit your amplifier or active speakers. With the volume set in the app, Primo V3 also works as a preamp, straight into a power amp.
Connections
Stream over Gigabit Ethernet or dual-band Wi-Fi. Then send the signal out balanced or unbalanced, or to a USB DAC.
The Volumio experience
Primo V3 runs Volumio OS, the player behind 800,000+ devices. You play it from the Volumio app, free on iPhone and Android.
Volumio OS inside
Premium features built in
Primo V3 has every Premium feature built in. TIDAL, Qobuz and Spotify sit next to internet radio such as Radio Paradise and TuneIn, in one place. TIDAL Connect, Qobuz Connect, Spotify Connect and AirPlay work too.
They belong to this Primo, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
Connect HDMI and browse your music on the big screen, in up to 4K at 60 fps.
Browse, play and control it all from the Volumio app, in lossless and high resolution.
Compare
Both are streamer DACs with the Premium features built in, and both measure 27 × 15 × 5.2 cm. Primo V3 moves to the ES9039Q2M DAC, plays up to PCM 384 kHz / 32-bit and adds adjustable outputs and NOS mode. Primo V2 keeps an S/PDIF coaxial output and comes in two finishes.
Latest generation
Buy in the shop, Primo V3
Classic or Florence Edition. iF Design Award 2024.
Buy in the shop, Primo V2Discover Primo V2Primo V3
Owner reviews
We count the crowd, not the faces in it. Analytics cookies only with your yes.
