There are no independent reviews of Lineo5 Duo yet.
Reviewers and owners have written about Lineo5, the model with one output.
Read the reviews of Lineo5Dual linear power supply
Two independent 5 V outputs, so one linear supply can power two devices.
Reviews
Read the reviews of Lineo5What it does
Lineo5 Duo takes the place of the external switching power supplies that run two of your devices, such as a streamer and a DAC. Its linear design gives each of them clean, stable 5 V power.
A switching supply and a linear supply.
A linear power supply holds a large reservoir of clean, stable power and keeps electrical noise low. Power delivery stays consistent, so you hear more of the detail and the transients in your music.
Linear regulation and filtering reduce ripple and interference. Each output of Lineo5 Duo has its own regulators and filtering, and the residual noise is 20 µV.
A toroidal transformer sits at the heart of Lineo5 Duo. It delivers the power each output needs with a wide margin, so it never comes close to its limits, even in the most demanding listening sessions.
Lineo5 Duo uses audio-grade, low-ESR capacitors with 40,000 µF of bulk capacitance, a large reservoir of power for the moments your system needs it most.
A simple, honest design. The chassis is aluminum, a robust and non-magnetic material, and the heatsinks along its sides cool the electronics passively.
A switch on the back sets the mains input: 110–120 V at 60 Hz, or 220–240 V at 50 Hz.
A fuse protects Lineo5 Duo, and it is easy to reach.
Stable, clean power for high-end DACs, headphone amplifiers and network streamers that run on 5 V.
Compatibility
Pick your device to see if Lineo5 Duo can power it. Lineo5 works with the same devices.
Your device
Motivo
Integro
Other 5 V gear
Lineo5 Duo is made for 5 V audio gear. Each of its two outputs gives 5 V DC, tip positive, through a cord that ends in a 5.5 × 2.1 mm barrel jack, with up to 4 A. Compare that with your device’s power input.
Works with the same devices.
See Lineo5
Lineo5 Duo with Rivo Plus and Preciso. Its two independent outputs can power two devices like these at the same time.
Compare
Both are linear 5 V supplies with a toroidal transformer, in the same 27.1 × 22.7 × 7 cm aluminum chassis, and they work with the same devices. Lineo5 has one output with up to 5 A. Lineo5 Duo has two independent outputs with up to 4 A each, so one supply can power two devices.
One output, up to 5 A
Buy in the shop, Lineo5Discover Lineo5
Two independent outputs, up to 4 A each
Buy in the shop, Lineo5 DuoThe Volumio experience
Lineo5 Duo gives cleaner power to Volumio streamers such as Rivo and Primo. They run Volumio OS: one player for all your music, on every screen in your home.
The player inside every Volumio streamer: every source, bit-perfect.
Set up, browse and play from your phone, on iOS and Android.
Lineo5 Duo
Owner reviews
Recommended with Lineo5 Duo
We count the crowd, not the faces in it. Analytics cookies only with your yes.
