Back to News
News
Optical Versus Coaxial Digital Audio Compared
A new DAC arrives, the music server is already playing, and there are two familiar ports on the back panel: optical and coaxial. Optical versus coaxial digital audio is not a contest with one universal winner. Both can carry excellent digital sound, but their physical designs solve different problems. The right choice depends on the gear in your system, the electrical environment around it, and the formats you intend to play.
For most two-channel systems, either connection can deliver a satisfying, detailed result when it is properly implemented. The more useful question is not which cable is inherently more “audiophile,” but which connection lets your streamer and DAC perform at their best together.
Optical Versus Coaxial Digital Audio: The Core Difference
Both optical and coaxial connections usually carry S/PDIF, a digital audio protocol found on streamers, CD transports, televisions, game consoles, and DACs. The audio data can be the same. What changes is the way that data travels.
Optical S/PDIF uses light. A source converts the electrical signal to pulses of light, which travel through a fiber-optic cable, commonly terminated with the square-shaped TOSLINK connector. At the receiving end, the DAC converts those light pulses back into an electrical signal.
Coaxial S/PDIF uses an electrical signal sent through a 75-ohm copper cable. RCA connectors are common on consumer hi-fi components, while BNC connectors appear on some higher-end equipment. The cable may resemble a conventional analog interconnect, but a true digital coaxial cable is designed to maintain the impedance required for reliable S/PDIF transmission.
That difference between light and electricity has practical consequences. Optical creates electrical isolation between source and DAC. Coaxial creates an electrical connection between them.
When Optical Is the Better Choice
Optical’s defining advantage is isolation. Because the signal crosses the cable as light, there is no direct ground path between the two components. That can be valuable when a system suffers from hum, buzz, computer noise, or other artifacts caused by ground loops.
This matters especially when connecting a television, computer, or cable box to a DAC or integrated amplifier. Video equipment and computers often share power with many other devices, and their electrical noise can find unwanted routes through an audio system. An optical cable breaks that route. If you hear a low-frequency hum with coaxial or analog connections, optical is often the first digital connection worth trying.
Optical is also convenient. TOSLINK cables are inexpensive, widely available, and immune to radio-frequency interference along the cable itself. For a television feeding a hi-fi system, it is frequently the cleanest, simplest answer.
There are trade-offs. The quality of the optical transmitter and receiver matters, and the standard’s real-world bandwidth can vary between components. Many optical outputs and inputs comfortably support CD-quality material and high-resolution PCM, but some are limited to 24-bit/96 kHz. Others handle 24-bit/192 kHz. Do not assume the connector alone tells you the maximum supported resolution. Check the specifications of both the sending device and the DAC.
Fiber-optic cables also deserve sensible handling. Avoid sharply bending, crushing, or loosely seating them. The small protective caps on a new TOSLINK cable are not glamorous, but removing them and ensuring each plug clicks fully into place prevents many frustrating no-signal moments.
When Coaxial Is the Better Choice
Coaxial digital is often favored for a dedicated audio source and DAC that sit in the same rack and are well designed. It can support higher sample rates more consistently across many components, and it is commonly available on CD transports, network streamers, and DACs built for serious two-channel listening.
A good coaxial connection can be particularly appealing if your library includes 24-bit/176.4 kHz or 24-bit/192 kHz PCM files and both components specify support for those rates over S/PDIF. It may also be the more dependable route for certain DSD-over-PCM implementations, although compatibility remains entirely device-specific.
Coaxial’s other advantage is mechanical familiarity. A properly made 75-ohm cable with secure RCA or BNC plugs is durable, easy to route, and less sensitive to tight bends than optical fiber. For a streamer placed close to a DAC, it is a straightforward, high-performing connection.
Its limitation is the same electrical link that makes it possible. If the source and DAC have different ground potentials, a coaxial cable can contribute to a ground-loop issue. This does not mean coaxial is noisy by nature. In a thoughtfully assembled system, it is often completely quiet. But if unwanted noise appears after connecting components, changing to optical is an easy diagnostic step.
Use a cable intended for 75-ohm digital transmission rather than treating any spare RCA cable as the ideal choice. A short analog interconnect may pass audio without obvious problems, but impedance mismatches can increase reflections and make a marginal connection less reliable. The goal is not an extravagant cable purchase. It is correct construction, good connectors, and a sensible length for the installation.
Does One Connection Sound Better?
The honest answer is: sometimes, but not for the reasons marketing shorthand suggests. Digital audio is not automatically immune to implementation quality. Timing behavior, electrical noise, receiver design, and a DAC’s clock recovery all influence what reaches the conversion stage.
Older or simpler DAC designs may respond more noticeably to differences between optical and coaxial inputs. A modern DAC with effective reclocking and input isolation may make the distinction very small. In that case, the quietest, most reliable connection that supports your desired formats is the better connection.
It is also worth separating audible changes from level differences, expectation, and setup variables. If you compare inputs, use the same track, the same DAC settings, comparable cable lengths where practical, and matched playback levels. Give each configuration time. A quick switch can reveal an obvious noise problem, but it is less reliable for judging subtle changes in tonal balance or imaging.
The source matters, too. A carefully configured network player running Volumio can organize local music and streaming services in one place, but the final result still depends on the digital output selected, the DAC’s input stage, and the rest of the system. The connection is one part of a longer chain that includes mastering quality, speaker placement, room acoustics, and listening level.
Choosing the Right Digital Connection for Your System
Start with compatibility. If your DAC only accepts up to 24-bit/96 kHz through optical and you regularly play higher-resolution PCM through a source that supports coaxial output, coaxial is the practical choice. If your music is largely CD quality, both options are likely to meet your needs easily.
Next, consider the source. For a TV, computer, or multi-purpose entertainment setup, optical is often preferable because it avoids electrical interaction with the audio system. For a dedicated streamer and DAC on the same equipment shelf, coaxial is often an excellent fit, provided the system is quiet.
Then consider the symptoms, not just the specifications. Choose optical if you are troubleshooting hum, buzz, or electrical noise. Choose coaxial if optical proves unstable at the sample rate you want to use, or if your DAC’s coaxial input is known to offer broader format support. If both work flawlessly, let listening decide rather than chasing a theoretical rule.
Cable length is rarely the first concern in a typical hi-fi rack, but avoid extremes. Keep the run tidy, protect optical cable from sharp bends, and use a correctly specified coaxial cable. Do not place excessive weight on claims that a cable alone will transform a system. Reliable transmission and clean system integration matter far more.
A Simple Way to Test Both
If your equipment provides both outputs and inputs, testing is worthwhile. Begin with coaxial, play several familiar recordings, and listen for clarity as well as silence between tracks. Then switch to optical with the same playback settings. Pay attention to obvious changes such as hum, intermittent lock, clicks when sample rates change, or a format that no longer plays at its native resolution.
If neither connection introduces noise or dropouts and both support your music, you have a fortunate result: either can be part of a refined digital front end. Select the one that keeps the installation clean and gives you confidence that every album, from a treasured local rip to a late-night streaming discovery, will play exactly as intended.
The best connection is the one that disappears once the first notes begin. Use optical when isolation brings peace to the system, use coaxial when its compatibility and stability suit your components, and spend the saved attention where it belongs: with the music.
Back to News
