Shop
Dual linear power supply
Lineo5 Duo
Two independent 5 V outputs, so one linear supply can power two devices.
Volumio Lineo5 Duo from the front: the same black aluminum case as Lineo5, with DUO printed on the right.
One device to power? Lineo5 has one 5 A output.
Discover Lineo5Compare the two
The highlights
  • 2 × 5V DCtwo independent outputs, to power two devices at once
  • 2 × 4Amaximum current, on each of the two outputs
  • 20µVresidual noise
  • 40,000µFbulk capacitance, from audio-grade low-ESR capacitors
  • Lineardual regulation, fed by a toroidal transformer
  • 6Volumio models it works with, two at a time, plus any other 5 V audio gear
Reviews
No reviews yet
There are no independent reviews of Lineo5 Duo yet.
Reviewers and owners have written about Lineo5, the model with one output.
Read the reviews of Lineo5
What it does
Cleaner power for 5 V gear
Lineo5 Duo takes the place of the external switching power supplies that run two of your devices, such as a streamer and a DAC. Its linear design gives each of them clean, stable 5 V power.
An illustration in two halves. On the left, labelled Switching PSU, a wavy line. On the right, labelled Linear PSU, a straight, steady band.
A switching supply and a linear supply.
A linear supply
A linear power supply holds a large reservoir of clean, stable power and keeps electrical noise low. Power delivery stays consistent, so you hear more of the detail and the transients in your music.
Less ripple and interference
Linear regulation and filtering reduce ripple and interference. Each output of Lineo5 Duo has its own regulators and filtering, and the residual noise is 20 µV.
The toroidal transformer inside Lineo5 Duo, seen from above: copper windings around a black cap and a central bolt, fixed to the floor of the chassis.
A toroidal transformer
A toroidal transformer sits at the heart of Lineo5 Duo. It delivers the power each output needs with a wide margin, so it never comes close to its limits, even in the most demanding listening sessions.
Inside Lineo5 Duo, seen from above: four large black capacitors on a green circuit board, with three small red components beside them and wires along the edges.
Audio-grade capacitors
Lineo5 Duo uses audio-grade, low-ESR capacitors with 40,000 µF of bulk capacitance, a large reservoir of power for the moments your system needs it most.
A render of Lineo5 Duo on a dark ground, with heatsink fins along its side and green light trails rising behind it.
Aluminum, cooled passively
A simple, honest design. The chassis is aluminum, a robust and non-magnetic material, and the heatsinks along its sides cool the electronics passively.
  • 110 or 220 V
    A switch on the back sets the mains input: 110–120 V at 60 Hz, or 220–240 V at 50 Hz.
  • An easy-to-reach fuse
    A fuse protects Lineo5 Duo, and it is easy to reach.
  • For 5 V audio gear
    Stable, clean power for high-end DACs, headphone amplifiers and network streamers that run on 5 V.
Compatibility
Will it power your device?
Pick your device to see if Lineo5 Duo can power it. Lineo5 works with the same devices.
Your device
Primo Plus
  • Lineo5 DuoCompatible
Discover Primo Plus
Primo V3
Discover Primo V3
Primo V2
Discover Primo V2
Motivo
  • Lineo5 DuoNot compatible
Rivo
Discover Rivo
Rivo Plus
Discover Rivo Plus
Preciso
Discover Preciso
Integro
Other 5 V gear
  • Lineo5 DuoCheck your device
Lineo5 Duo is made for 5 V audio gear. Each of its two outputs gives 5 V DC, tip positive, through a cord that ends in a 5.5 × 2.1 mm barrel jack, with up to 4 A. Compare that with your device’s power input.
Lineo5 Duo
Not compatible
Lineo5
Works with the same devices.
See Lineo5
Lineo5 Duo on a concrete step, with Rivo Plus and Preciso side by side on the step below and a soft green light on the wall behind.
Lineo5 Duo with Rivo Plus and Preciso. Its two independent outputs can power two devices like these at the same time.
Compare
Lineo5 Duo or Lineo5
Both are linear 5 V supplies with a toroidal transformer, in the same 27.1 × 22.7 × 7 cm aluminum chassis, and they work with the same devices. Lineo5 has one output with up to 5 A. Lineo5 Duo has two independent outputs with up to 4 A each, so one supply can power two devices.
Maximum current per output, in Ampere
Lineo5
5 A
Lineo5 Duo, output 1
4 A
Lineo5 Duo, output 2
4 A
Outputs
Lineo5: 1
Lineo5 Duo: 2, independent, each with its own regulators and filtering
Output current
Lineo5: Up to 5 A
Lineo5 Duo: Up to 4 A on each output
Regulation
Lineo5: Linear
Lineo5 Duo: Dual linear
Power consumption
Lineo5: Up to 90 W
Lineo5 Duo: Up to 120 W
In the box
Lineo5: 4 AC power cables (EU, US, UK, AU/NZ) and 1 output cable
Lineo5 Duo: 4 AC power cables (EU, US, UK, AU/NZ) and 2 output cables
On both
5 V DC, tip positive, from GX-16 sockets with 2 pins, and output cords that end in a 5.5 × 2.1 mm barrel jack. Mains input of 110–120 V at 60 Hz or 220–240 V at 50 Hz, set with a switch. A toroidal transformer, audio-grade low-ESR capacitors with 40,000 µF of bulk capacitance, filtering that reduces ripple and interference, 20 µV of residual noise, and an easy-to-reach fuse. An aluminum chassis with heatsinks, 27.1 × 22.7 × 7 cm. Compatible with the same devices.
The Volumio experience
Made for the Volumio experience
Lineo5 Duo gives cleaner power to Volumio streamers such as Rivo and Primo. They run Volumio OS: one player for all your music, on every screen in your home.
  • Volumio OS
    The player inside every Volumio streamer: every source, bit-perfect.
  • The Volumio app
    Set up, browse and play from your phone, on iOS and Android.
Discover the Volumio experience
Lineo5 Duo
Tech specs
Lineo5 Duo hardware specifications
Input voltage
110–120 V / 60 Hz (AC) or 220–240 V / 50 Hz (AC)
Output voltage
2 × 5 V (DC)
Output current
2 × 4 A (max)
Power consumption
120 W (max)
Transformer type
Toroidal
Design
Dual linear regulation
Circuit protection
Easy to access fuse
Filtering
Reduced ripple and interference
Capacitors
Audio-grade, low-ESR
Bulk capacitance
40,000 µF
Residual noise
20 µV
Connectors
GX-16 (2 pins)
Output power cord
GX-16 (2 pins) to barrel jack (5.5 × 2.1 mm)
Output cable length
115 cm (45.3 in)
Output polarity
Tip positive
Dimensions
27.1 × 22.7 × 7 cm (10.7 × 8.9 × 2.8 in)
Weight
4.02 kg (8.86 lb)
Box dimensions
37.5 × 35 × 17.5 cm (14.8 × 13.8 × 6.9 in)
Box weight
5.5 kg (12.13 lb)
Compatibility
Compatible
Primo Plus, Primo V3, Primo V2, Rivo, Rivo Plus, Preciso
Not compatible
Motivo, Integro
The back of Lineo5 Duo, from left: two round output sockets with two pins each and polarity markings, a red switch marked VOLTAGE SELECTOR set to 220V, and the mains power inlet.
Lineo5 Duo in the box
  • Volumio Lineo5 Duo
  • 4 AC power cables: EU, US, UK and AU/NZ
  • 2 output cables, each 115 cm long, GX-16 (2 pins) to a 5.5 × 2.1 mm barrel jack, tip positive
Read the Lineo5 Duo user manual
