Shop
Streamer transport
Rivo Plus
The enhanced Rivo, with a dedicated ASIC for its S/PDIF coaxial and AES/EBU outputs, upgraded MEMS clocks and I2S over HDMI.
4.8 · 29 reviews
Volumio Rivo Plus in the Classic finish, from the front: a deep blue front panel with the Rivo+ name and a square grey button lit in blue, in a grey case.
The highlights
  • Volumio OSinside, Volumio Premium built in. Works with TIDAL, Qobuz, Spotify Connect, AirPlay and Roon Ready (subscriptions sold separately)
  • 1536kHzPCM at 32-bit and DSD1024 over USB, with multiroom off
  • 768kHzPCM at 32-bit and up to DSD512, on the I2S over HDMI output
  • 192kHzPCM at 24-bit and DSD64 via DoP, on S/PDIF coaxial and AES/EBU
  • 4digital outputs: USB, I2S over HDMI, AES/EBU and S/PDIF coaxial
  • 12Vtrigger output, to switch your other components on and off
Reviews
What reviewers and owners say
A British Audiophile badge: Best Source Component, 2025, £1,000 to £2,000
A British Audiophile, 2025
For components from £1,000 to £2,000.
Independent reviews
  • Alpha Audio Approved · Sound 100%
    “…confidence that the Rivo+ brings to the sound of the DAC is particularly striking.”
    September 2025 · Read the review in Alpha Audio
  • FWD 9.0/10 · Kooptip award
    “What is truly brilliant about this streamer, though, is the modular Volumio software.”
    Jamie Biesemans · May 2025 · In Dutch, quote translated · Read the review in FWD
  • Hifi Pig 5 Hearts award
    “It’s a great player for the money – well-featured and good sounding…”
    Stuart Smith · March 2025 · Read the review in Hifi Pig
  • Audiophilia Highly recommended
    “The Rivo+ is a set-it-and-forget-it device that sounds great and has excellent functionality.”
    Jesús González-Monreal · April 2025 · Read the review in Audiophilia
  • SECRETS of Home Theater and High Fidelity
    “I was very impressed with the Volumio Rivo Plus.”
    Chris Groppi · May 2025 · Read the review in SECRETS of Home Theater and High Fidelity
  • 6moons
    “In that respect, the Volumio Rivo+ succeeds with honours.”
    Frederic Beudot · March 2026 · Read the review in 6moons
From owners
4.8
29 reviews on shop.volumio.com
  • “The Rivo Plus puts a smile on my face.”
    Ruud Nauta · December 2025
  • “Setup is easy, the Rivo+ paired with a good DAC sounds phenomenal.”
    Carty Ross · July 2026
Read all 29 reviews
Rivo Plus in the Classic finish on a wooden shelf, next to two potted succulents and a white speaker.
Rivo Plus is designed and assembled in Florence, like every Volumio product.
Two Volumio team members check a main board at the assembly table in Florence, with a stack of finished boards beside them.
Made in Florence
Assembled by hand, in Italy
Rivo Plus is designed in Florence and assembled there by hand, by the team that also writes its software. Each unit is checked before it leaves the lab.
More about Volumio in Florence
Look inside
Cleaner outputs. Steadier clocks.
Rivo Plus is the enhanced version of Rivo, engineered from what listeners asked for. A dedicated ASIC now generates the S/PDIF coaxial and AES/EBU signals, and improved MEMS clocks lower jitter.
At a workbench, a person in a white T-shirt holds a dark circuit board above rows of more boards.
A dedicated ASIC
An ASIC is a chip built for one task. Here it generates the S/PDIF coaxial and AES/EBU output signals. This takes the job off the main processor, so its interference and jitter stay out of these outputs.
A MEMS clock and quiet power
A high-quality MEMS (micro-electro-mechanical systems) clock drives the ASIC and gives it a very stable, low-jitter timing reference. Low-noise voltage regulators power it.
Reclocked USB
An upgraded MEMS clock in the USB hub chip improves reclocking and signal integrity, above all on the USB DAC output. It keeps jitter low and the frequency stable, with less drift from temperature changes and aging.
Outputs
Four ways to your DAC
Rivo Plus is a digital transport. It sends the signal to your DAC through USB, I2S over HDMI, AES/EBU or S/PDIF coaxial. A 12 V trigger switches your other components on and off.
USB
1536kHz
Up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. The USB-A 2.0 output has power filtering, and an upgraded MEMS clock in the USB hub chip improves its reclocking.
I2S over HDMI
768kHz
Up to PCM 768 kHz / 32-bit and DSD512, with multiroom off. For compatible DACs. The pinout routing of the HDMI connector is adjustable.
192kHz
Up to PCM 192 kHz / 24-bit and DSD64 via DoP, on both. The dedicated ASIC generates both signals, with its own MEMS clock and a low-noise power supply.
Trigger
12V
A trigger output on a 3.5 mm jack, positive on tip. It switches your other components on and off.
Connections
From your network to your DAC
Stream over Gigabit Ethernet or dual-band Wi-Fi, or play from a USB drive. On the back, I2S and video each have their own HDMI connector.
The back of Rivo Plus, labelled from left: USB, NET, Micro SD, HDMI, a USB-C port, USB, USB DAC, I2S, AES EBU, COAXIAL, TRIG OUT and DC 5V-3A.
In
Ethernet
Gigabit, 10/100/1000
Wi-Fi
802.11a/b/g/n/ac, 2.4 and 5 GHz
USB-A × 2
Flash drives, HDD and SSD, on one USB 2.0 and one USB 3.0 port
Power
5 V DC / 3 A, on a 5.5 × 2.1 mm barrel jack
Out
USB DAC
USB-A 2.0 with power filtering
I2S
HDMI connector with adjustable pinout routing
AES/EBU
XLR connector, fed by the dedicated ASIC
S/PDIF coaxial
RCA connector, fed by the dedicated ASIC
HDMI
Mirrors the Volumio app on your TV, up to 4K at 60 fps
Trigger
12 V on a 3.5 mm jack, positive on tip
The Volumio experience
Rivo Plus runs Volumio OS, the player behind 800,000+ devices. You play it from the Volumio app, free on iPhone and Android.
Rivo Plus, front viewVolumio OS inside
Rivo Plus plays everythingTIDAL, Qobuz, Spotify Connect, AirPlay, Roon Ready, web radio and your own files, bit-perfect. Volumio Premium built in; streaming subscriptions sold separately.
The Volumio app on a phone, playing an album: the cover, the controls and the volume.
You play it from the appSearch every service at once, play in every room, and control it from any phone, tablet or browser. Or on your TV, over HDMI.
Discover the Volumio experience
Premium features built in
Your music, all in one place
Volumio Premium built in. Stream with your TIDAL, Qobuz or Spotify account, plus their Connect features and AirPlay. Play local or network drives, or internet radio.
The Premium features belong to this Rivo Plus, with no subscription. On a Raspberry Pi or a PC, the same features come with a Volumio Premium subscription.
A living room with a TV showing album art and track details, above a dark wooden sideboard with books, records and Rivo Plus.
On your TV
Connect HDMI and browse your music on the big screen, in up to 4K at 60 fps.
A listener holding a tablet that shows a music library, with Rivo Plus on a sideboard under the TV behind him.
In your hand
Getting started takes a couple of minutes with the Volumio app for iOS and Android.
App StoreGoogle Play
  • Supersearch
    An AI-powered search that helps you discover music.
  • Multiroom
    Links Rivo Plus with the other Volumio players in your home.
  • Roon Ready
    Certified by Roon Labs, so Rivo Plus works with Roon.
Finishes
Classic or Special Edition
Rivo Plus comes in two finishes. The Special Edition has a refined brown leather finish, inspired by Italian craftsmanship.
Rivo Plus in the Classic finish on a wooden shelf, in front of a stack of books.
Classic
A deep blue front with a square button, in a grey case.
Rivo Plus Special Edition on a wooden sideboard, with brown leather on the front and a diamond-stitched top, next to a plant, records and a TV.
Special Edition
Brown leather on the front, and a diamond-stitched leather top.
Compare
Rivo Plus or Rivo
Both are streamer transports with the Premium features built in, the same processor and the same USB DAC output, and both measure 27 × 15 × 5.2 cm. Rivo Plus adds a dedicated ASIC for the S/PDIF coaxial and AES/EBU outputs, upgraded MEMS clocks, I2S over HDMI and a 12 V trigger.
Rivo Plus: Up to PCM 192 kHz / 24-bit and DSD64 via DoP
Rivo: Up to PCM 192 kHz / 24-bit
Dedicated output ASIC
Rivo Plus: Yes, for S/PDIF coaxial and AES/EBU, with its own MEMS clock
Rivo: Not available
USB clock
Rivo Plus: Upgraded MEMS clock in the USB hub chip
Rivo: Standard clock in the USB hub chip
Rivo Plus: Up to PCM 768 kHz / 32-bit and DSD512
Rivo: Not available
12 V trigger output
Rivo Plus: Yes, on a 3.5 mm jack
Rivo: Not available
Finishes
Rivo Plus: Classic, or the Special Edition in brown leather
Rivo: Classic, or the limited Black Edition in black upcycled leather
On both
USB DAC output up to PCM 1536 kHz / 32-bit and DSD1024, with multiroom off. ARM Cortex-A55 quad-core processor at 1.9 GHz, 2 GB DDR4 and 16 GB eMMC. Gigabit Ethernet, dual-band Wi-Fi and Bluetooth 5.0. HDMI up to 4K / 60 fps. 5 V / 3 A power. 27 × 15 × 5.2 cm and 1.12 kg. Premium features built in.
means not available on that model.
Rivo Plus
Tech specs
Audio specifications
USB output
Up to PCM 1536 kHz / 32 bit and DSD1024, with multiroom off
Up to PCM 768 kHz / 32 bit and DSD512, with multiroom off
S/PDIF coaxial output
Up to PCM 192 kHz / 24 bit and DSD64 via DoP
AES/EBU output
Supported formats
Supported services
UPnP/DLNA
Plugins
Hardware specifications
USB DAC output
1 × USB-A 2.0 with power filtering and signal-integrity reconstruction
USB host
1 × USB-A 2.0, 1 × USB-A 3.0 (USB Flash Drive and HDD/SSD)
I2S output
1 × HDMI with adjustable pinout routing
Video output
Trigger out
1 × 3.5 mm jack (12 V, positive on tip)
LAN
Gigabit 10/100/1000 Mbps
Wi-Fi
Bluetooth
5.0
CPU
ARM Cortex-A55, Quad Core 1.9 GHz
RAM
2 GB DDR4
Internal storage
16 GB eMMC
Power
5 V DC / 3 A
Power input
Finishes
Dimensions
27 × 15 × 5.2 cm (10.6 × 5.9 × 2.0 in)
Weight
1.12 kg (2.47 lb)
Box dimensions
31.5 × 19.7 × 11.6 cm (12.4 × 7.8 × 4.6 in)
Box weight
1.96 kg (4.32 lb)
Rivo Plus from the front left, in the Classic finish.
In the box
  • Volumio Rivo Plus
  • 5 V / 3 A power supply
  • NFC and QR code information card
Read the user manual
Better together
Rivo Plus and Preciso
Rivo Plus streams, Preciso turns the signal into analog sound. Same size, so they stack.
Buy both in the shop
